Activity Forums Adobe After Effects ae ram preview on kona2?
  • Chris Wyatt
    May 16, 2007 at 11:57 am
    Hi sami kallinen
    one can indeed preview ae through kona 2. After installing the Kona 2 use the Aja Kona control panel application and under the control tab set the default Kona output to macintosh desktop. Under display in system preferences tick the radio button ‘show displays in menu bar’. Set your display to PAL or NTSC or your preferred HD format.
    In after Effects 6.5, 7.0 or CS3 beta under the preferences item ‘video preview’ you should see
    the Kona 2 as an option for RAM preview.
    Best Regards
    Footagehead
  • Sami Kallinen
    May 16, 2007 at 12:53 pm
    thanks for your reply!
