Activity Forums Adobe After Effects AE project reverted to a previous version | Work lost
  • AE project reverted to a previous version | Work lost
    Posted by Razvan Dimitriu on January 5, 2015 at 8:24 pm
    Working on Windows 7, AE CS6.
    I started this project around the 20th of December. Today I made some revisions on it and rendered them, everything normal.
    Then I opened up an older project. After that, I got back to the current project and saw a lot of stuff missing (both comps and assets). I don’t remember saving the project in this state (although I’m not 100% sure).
    Then I went to the location of the project file – here I found the project file (last modified just a few minutes before) and the auto-save folder, which has the last version dating from the 23rd of December.
    Everything else in the folder (all the assets and render files for the project) are there, so the only thing that seemed to change is the AEP file and the auto-saves missing.
    The only thing I could think of was that maybe I accidentally saved the project in another location (maybe with another name) so I searched my computer for all AEP files and went through those – nothing.
    It’s very hard to accept that all of a sudden a few days of work were lost, so I’m praying that someone will show me what a fool I am 🙂
    Tracy Kazanjy replied 10 years, 6 months ago 3 Members · 6 Replies
  • Razvan Dimitriu
    January 5, 2015 at 8:36 pm
    That’s what I was thinking at first, but it’s not there. And as I said, I did a search for *.aep on my harddrives and looked at everything modified in the last two weeks and nothing.
  • Razvan Dimitriu
    January 5, 2015 at 8:55 pm
    Or if that could be the case, is there any log file or an extended version of the Recent Projects list?
    Colorist, Online Editor
    https://retinastudio.ro/
  • Walter Soyka
    January 5, 2015 at 9:01 pm
    [Razvan Dimitriu] “Today I made some revisions on it and rendered them, everything normal.”
    By default, Ae writes the path and filename of the original AEP into the XMP metadata for your rendered output (on supported output formats).
    Import your render into Premiere, then right-click it and choose “Edit Original.” It should open the AEP file which rendered it out. If your changes aren’t there, you probably didn’t save.
    My general save advice: get in the habit of using Increment and Save often (instead of regular save) to minimize the chance of losing work. If you increment every major change you make, you’ll only lose a couple hours of work tops. Also, consider keeping your project files synced with Dropbox, which can do its own automatic versioning.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Razvan Dimitriu
    January 5, 2015 at 9:12 pm
    Thanks, I’ll give that a try tomorrow when I get back to the office.
  • Razvan Dimitriu
    January 6, 2015 at 8:57 am
    You guys were both right. It was saved in another location. The Premiere trick did it. That’s a nice one, Walter!
    Note to self: don’t do troubleshooting when tired. Leave it to the next morning.
    Thanks a lot and sorry for the false alarm!
  • Tracy Kazanjy
    February 15, 2016 at 9:38 pm
    You just saved me! I somehow lost my AEP files after rending them. It’s a simple school project, but we needed to have the rendered files and the AEP files, and all I had left were the rendered files. I don’t know how or why they disappeared (I save early and often to the Dropbox folder on my desktop), but I followed your instructions to import the rendered files to Premiere and “Edit Original”, and was able to retrieve the missing files.
    Thank you, thank you!!!
