Activity › Forums › Adobe After Effects › AE project file path
  • AE project file path
    Posted by Anthony Dupsta on September 25, 2006 at 6:17 pm
    I need to figure out a way to determine the file path of an AE project, while working within the project.
    I will have duplicate AE project files after executing a collect (project only). I need to determine which AE project is currently open , the local version or duplicated project? Viewing the path would tell me exactly which project I am currently working in or need to be in.
    Thank you
    Win XP
    AE 07
    Thank you
    Anthony Dupsta replied 20 years ago 2 Members · 2 Replies
  • Roland R. kahlenberg
    September 26, 2006 at 3:39 am
    If you close the AEP and then reach for the File Menu, you will be able to see the filepath of the AEP that you last worked on, in the Recent Projects sub-menu.
    HTH
    Roland Kahlenberg
    broadcastGEMs
    customizable animated backdrops with Adobe After Effects project files
  • Anthony Dupsta
    September 27, 2006 at 11:00 pm
    There must be another way! Thast seem so backwards.
    I appreciate your post, thanks , for know I will just keep using save as instead, tht works sometimes better.
    This couls be an XP thing but I would think Adobe might be able to work this in.
