Activity Forums Adobe After Effects AE problem with fps
  • AE problem with fps
    Posted by Jeroen De mol on September 18, 2008 at 1:05 pm
    Hi everybody, I am having a small problem in AE 8. I just started using it, but been a FCP user for years.
    I have a quicktime movie at 25 fps, when I import it into AE and make a new comp with it, AE sais the footage is 32 fps and plays it at 32 fps. The weird thing is, when I change the comp settings to 25 the footage starts to stutter. I’m pretty sure the footage is 25 fps, since it’s a screen capture done with Snapz Pro X at 25 fps.
    Am I missing something here?
    Thanks in advance.
    Jeroen De mol replied 18 years ago 2 Members · 2 Replies
  • Mark
    September 18, 2008 at 1:30 pm
    Open the quicktime in the quicktime player and check the frame rate there to make sure that it is really 25. If it is, then right click on the footage and go the intepret footage dialog box and select 25fps…Now drop that into a 25fps comp and all should play well.
    Regards
    Mark
    Mark Harvey
    Senior Editor
    Le R
  • Jeroen De mol
    September 18, 2008 at 1:35 pm
    I checked, and it sais 25 fps. I’ll do the intepret footage. Thanks. 🙂
