Activity Forums Adobe After Effects AE problem with audio driver
  • AE problem with audio driver
    Posted by Ofeq Shemer on September 8, 2008 at 4:34 pm
    hello
    i play sound on my computer through digidesign MBOX 2 with ASIO digidesign driver.
    after effects worked ok with it for a while and its just stoped working! i see the cursor move in audio preview but i dont hear any sound.
    it sends the sounds to the windows audio driver, i know that because i hear it when i plug headphones diractly to the computer.
    the windows settings is correct btw (set to the MBOX 2)…
    can anyone help?
    thankyou
    Ofeq Shemer replied 17 years, 11 months ago 2 Members · 4 Replies
  • Laurie Turner
    September 8, 2008 at 7:23 pm
    did you try restarting everything? I work with Mbox 2 and sometimes that’s all it needs.
    can you hear the audio through any other applications?
  • Ofeq Shemer
    September 8, 2008 at 9:26 pm
    yeah. restarted everything 5 times. still doesn’t work.
  • Laurie Turner
    September 9, 2008 at 12:59 pm
    When you open preferences and go to Audio Hardware, is that set up properly too?
    Do you only have this problem with AE?
  • Ofeq Shemer
    September 9, 2008 at 1:44 pm
    yes it is set up properely.
    but i just noticed that if i play a comp that does not envolve any effects from the sound menu- it works.
    it stops playing just when i’m trying to use effects on a sound layer.
    still very annoying.
    about you question-
    pro tools plays
    windows media player plays
    quicktime plays but not good at all
    after effects- as i said.
    i didn’t tried anything else…
