Activity Forums Adobe After Effects AE Pet Peeve – Importing Files
  • AE Pet Peeve – Importing Files
    Posted by Dale Kutzera on June 28, 2012 at 2:38 am
    When I import a file, sometimes I have to double click a folder to reach the file within. When I do this in AE-Import, instead of opening the folder, it imports the whole thing. To get around this, I use that column format finder window to just open the folder and not import it. Kind of a pet peeve of mine, but I’m probably doing it wrong.
    Joseph W. bourke replied 14 years, 2 months ago 3 Members · 3 Replies
  • Jim Arco
    June 28, 2012 at 11:28 am
    You can drag-and-drop files into the AE project window.
    Jim
  • Dale Kutzera
    June 28, 2012 at 1:26 pm
    Yes, bu my pet peeve is opening the folder the file is within. If I want to open a file in say Word, I can double click the folder in the “open” window and it will reveal all the files inside. When I do this in AE…it imports the entire folder.
  • Joseph W. bourke
    June 28, 2012 at 2:10 pm
    Maybe if you think about it as a “push” operation as opposed to a “pull” one, it will get you there quicker – I use Bridge to track and manage all of my project files, and any project I’m working on is saved in the Favorites tab. It’s a simple matter to open Bridge (which is usually open anyway), view the files I’m about to use, sort or select them, then drag and drop into AE.
    The whole sort/select process I’m talking about is done before hand, so it’s really a one step operation. I pick my selects, then either label or keyword them in Bridge, so with a single click, I can be looking at just the files I’m about to import (.mov for example). I then Shift or Control select and drag them into the Project in AE.
    Joe Bourke
    Owner/Creative Director
    Bourke Media
    http://www.bourkemedia.com
