Activity Forums Adobe After Effects AE output to: create new subdirectory with comp name in output folder
  • AE output to: create new subdirectory with comp name in output folder
    Posted by Chris Gwynne on February 13, 2011 at 10:15 am
    Is there a way to have AE automatically create a subfolder in the main output folder for each comp with the comp name and render the sequence for each comp into its own subfolder?
    Have 125 comps and I’m trying not to manually create 125 subfolders and then manually select each one as the output folder when I add a comp to the render queue. And I can’t find such an option in the output filename templates.
    Chris Gwynne replied 15 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
