Activity Forums Adobe After Effects AE Output module template
  • AE Output module template
    Posted by Payal on September 2, 2005 at 5:14 pm
    Hi all,
    I have a 2 template projects set up for rendering. So whenever I want to make a quicktime, I use one of the templates. I have two render nodes which do this job. Both the project templates use the same “Render Settings template” but have different “Output module templates”. But my render nodes only see one set. It does not recognize the other “Output module template” for the second project.
    How do I get around this? Can’t I force AE to use different Render templates for different projects?
    Payal
    Payal replied 21 years ago 3,546 Members · 1 Reply
  • Payal
    September 2, 2005 at 5:33 pm
    Problem solved. I use aerender command to make a quicktime. I can specify the output module template I want to use. I had completely forgotton about that.
    Thanks.
