Activity Forums Adobe After Effects AE output for front projection
  • AE output for front projection
    Posted by Simon Levshin on August 23, 2008 at 3:24 am
    Hi everyone,
    I’m doing a project that will viewed on a 4:3 screen front projection.
    Just wondering what is the correct format to render out my files. It should be PAL as I’m in Australia, but what frame size? Can I use 768 x 576 square pixels? Also how do I add chapters as this will be on DVD?
    thanks in advance.
    Ben Trahair replied 18 years, 1 month ago 2 Members · 1 Reply
  • Ben Trahair
    August 23, 2008 at 9:43 am
    For a 4:3 Pal frame 720 x 576 D1/DV non square pixels (1.07) would be what I would use. What DVD authoring software are you intending on using to create the DVD? That will probably determine where/how you set chapter markers.
    Ben Trahair
    http://www.bentrahair.com
