Activity Forums Adobe After Effects AE or Flash??
  • AE or Flash??
    Posted by Dvlisarrr on February 15, 2006 at 9:06 am
    Since AE can export to .swf or .fla, is there any reason not to use AE to create all of my flash animations? I own flash 8 but find the interface counter-intuitive. (and why can’t they convert the timeline to seconds instead of frames or am i missing something?)
    Anyways, I’m wanting to do just images and text fading in and out and to post them as a .swf on a website. Any reason not to do this in AE?
    Thanks in advance!
    Graham Quince replied 20 years, 7 months ago 3 Members · 6 Replies
  • Chris Figat
    February 15, 2006 at 3:16 pm
    primarily because AE isn’t vector and as such creates FAR bigger files for that sort of thing than flash does. if you’re needing to do something that’ll be viewed on a cd or something similar than AE would be great, but for web stuff flash is usually still the best option.
    chris
  • Dvlisarrr
    February 15, 2006 at 5:15 pm
    Thanks Chris, but AE now exports text as vector art when exporting to Flash (as either a swf or fla), so I don’t see the difference…. ?
  • Chris Figat
    February 15, 2006 at 6:36 pm
    i haven’t looked into AE 7 much yet, but if it is in fact vector and scalable and the file size is comparable then go for it 🙂 only real reason to use flash would be file size considerations or if you need to add in additional controls to the movie.
    chris
  • Dvlisarrr
    February 15, 2006 at 7:57 pm
    It actually works in 6.5 as well. Here’s some good info for you! https://www.creativecow.net/articles/brimelow_lee/ae4flash1/ae4flash1.html
  • Chris Figat
    February 15, 2006 at 9:13 pm
    I’d somehow missed that one, i’ll check it out, thanks 🙂
    chris
  • Graham Quince
    February 20, 2006 at 8:01 am
    There are still issues using After Effects to create Flash animations. Flash can only accept one mask bringing in AE swfs, for instance. In the past I’ve used a Flash reduction program, Flash Optimiizer, it saves about 20% of the file size.
    I’ve knuckled down and learnt how to use Flash though. It’s well worth it, although if you’re still not happy, then SWiSH Max is a cheap standalone Flash program that creates easy animations and even has guided scripting. Might be worth checking out.
    Graham
    https://www.qcit.co.uk – web design
    https://www.shiveringcactus.bravehost.com – Free FX for amateur films
