Activity Forums Adobe After Effects AE on a PC
  • AE on a PC
    Posted by Richard Bachman on April 5, 2007 at 2:53 pm
    I’ve heard conflicting (mostly negative) reports on AE’s performance on a PC. I have used 6.5 on OSX for years and would desperately love to add AE at my new gig – but they only use IBM laptop setups…
    Any experience with this?
    Solie Swan replied 19 years, 5 months ago 8 Members · 13 Replies
  • 13 Replies
  • Jimmy Brunger
    April 5, 2007 at 3:26 pm
    Works fine here!?! Until CS3 comes out you will only get *better* performance on a PC, since the mac version isn’t Intel friendly yet.
    *Production Studio Premium / *Combustion 3
    Win XP Pro SP2 / Intel P4 3GHz / 2GB RAM / GeForce FX5200 / DeckLink Pro / Sony BVM-20G1E / DVS SDI Clipstation / 110GB boot/80GB media/600GB RAID-0
  • Richard Bachman
    April 5, 2007 at 3:33 pm
    This brings up another question I had – I’ve read up on the Adobe Creative Suite Production Premium bundle (Illustrator, Photoshop, Flash, AE, Premiere, Soundbooth, Encore)and it all looks extremely impressive – especially for only $1800.00 – but it’s not due to be released for several months.
    Is there a similar bundle available now that will allow you to upgrade once the CS3 version comes out – and if so, has anyone worked with it (again, on a PC.) I’ve tried to find this info on the Adobe site, but cannot for some reason.
  • Jimmy Brunger
    April 5, 2007 at 3:49 pm
    I am running Production Suite Premium on my PC at the moment. It contains CS2 PS+ILL, PremPRO2, Encore2, AE7 and Audition2. Works great for me.
    You should still be able to get this for PC now and then upgrade to CS3 when it comes out.
  • Steve Roberts
    April 5, 2007 at 4:44 pm
    It works fine on a PC. Befor IntelMacs, the experience was identical on both platforms.
    Once you got used to the ctrl/cmd difference. 🙂
  • Darby Edelen
    April 5, 2007 at 5:05 pm
    [jimmybee500] “Until CS3 comes out you will only get *better* performance on a PC, since the mac version isn’t Intel friendly yet.”
    That’s assuming that you’re not still using a G5 =O
  • Brian Charles
    April 5, 2007 at 5:20 pm
    I use both Mac’s and PC’s. My current Mac config is a G5 Quad 2.66 with 4.5 GB of RAM 0S 10.4.9, my PC config is a Quad Core Xeon 2.6 with 4 GB of RAM, XP Pro 32 bit, SP2. Yes, I own the software on both platforms. (The upgrade to CS3 will cost me dearly =0).
    For sheer After Effects performnace the PC spanks the Mac. It previews and renders at more than twice the speed. I have Nucleo Pro on the Mac and it will render some files more quickly but in general it is much slower. After Effects 7 can only use 2 GB of RAM on the PC but can use 3 GB on the Mac. This can make a difference on some renders as After Effects uses RAM to cache files.
    When CS3 arrives it will take advantage of multi-core/multi-processor and should post performance gains on both platforms.
    All that said, its your workflow that really makes a real world difference. I prefer working on the Mac, the OS is smarter, managing files is easier.
    As well, despite owning the Production Suite on the PC, I prefer editing in Final Cut.
    The real difference in platforms has less to do with performance and more with user/workflow experience.
  • Steve Roberts
    April 5, 2007 at 5:42 pm
    [Brian Charles] “The real difference in platforms has less to do with performance and more with user/workflow experience.”
    Amen, brother.
  • Jamesc
    April 5, 2007 at 6:21 pm
    “After Effects 7 can only use 2 GB of RAM on the PC but can use 3 GB on the Mac.”
    You need to investigate the /3GB switch – Google it.
    Basically you add /3GB to your boot.ini file and this allows XP to access 3Gb :o)
  • Jamesc
    April 5, 2007 at 6:22 pm
    Sorry – I mean – AE to access 3Gb…
  • Brian Charles
    April 5, 2007 at 10:21 pm
    I’ve modified the boot.ini to enable the 3GB switch and found the system became unstable.
