Activity › Forums › Adobe After Effects › AE (null)
AE (null)
Posted by Johnsabbath D’urzo on July 12, 2009 at 9:53 pmI’m running :Activity Monitor the after effects logo says (null) beside it, would you know what that means?
Kevin Camp replied 17 years, 2 months ago 4 Members · 5 Replies -
Steve Roberts
July 13, 2009 at 6:47 amGoogling “activity monitor” and “null” led to this:
https://forums.macnn.com/90/mac-os-x/188750/what-is-null-my-activity-monitor/ -
Johnsabbath D’urzo
July 13, 2009 at 2:15 pmjust checked out this forum, I don’t have classic running on that system. Does anyone know what this means AE (null) would it relate to anything else?
David Bogie
July 13, 2009 at 3:14 pmIs this bothering you just because you can’t figure it out or is this a real problem?
bogiesan
Johnsabbath D’urzo
July 13, 2009 at 4:03 pmjust wondering what it is and if its something i should be concerned about. would you know what it means?
Kevin Camp
July 13, 2009 at 5:11 pmi don’t know why the ae app comes up as (null) in the activity monitor, but it is normal (at least it says the same for me) and i don’t think yo need to be concerned about it.
just know that it is the ae foreground process.
if you have ‘render multiple frames simultaneously’ enabled you will also see several other ae background processes running called aeselflink. those are the render engines that are running on each available core. when rendering with mp enabled, these will do most of the work and should be consuming the processor cycles. if not enabled, the ae (null) process will be using all the cycles.
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW
