Activity Forums Adobe After Effects AE not seeing alpha on it’s own exports
  • AE not seeing alpha on it’s own exports
    Posted by Zak Ray on August 19, 2010 at 2:38 pm
    Hi all,
    Probably something simple, but it seems that AE doesn’t want to see an alpha channel on clips that I’ve exported. That is to say, I export a clip (which I can then drag into PS to verify that it does indeed have an alpha), then bring it back to AE, where it doesn’t see the alpha. The alpha interpretation settings are also grayed out when I attempt to change them.
    Any thoughts? Thanks!
    David Johnson replied 16 years, 1 month ago 5 Members · 11 Replies
  • 11 Replies
  • Zak Ray
    August 19, 2010 at 2:54 pm
    Thanks Dave. As I indicated, there’s definitely an alpha there when I export, because Photoshop sees it when I open it there. I’ve been using ProRes4444, but I don’t think the problem is the export settings.
  • Tudor “ted” jelescu
    August 19, 2010 at 2:56 pm
    Have you tried a different codec?
    What version of AE are you running?
    Tudor “Ted” Jelescu
    Senior Compositor/VFX Artist
    Bucharest, Romania
  • Zak Ray
    August 19, 2010 at 3:00 pm
    Hm, tried Animation and it seems to work. That said, I’d still like to be able to use ProRes if possible.
    Running AE CS5.
    August 19, 2010 at 3:05 pm
    post this on the Adobe site – maybe it’s a bug in CS5
    Tudor “Ted” Jelescu
    Bucharest, Romania
  • Zak Ray
    August 19, 2010 at 3:08 pm
    You mean as a bug report?
  • Walter Soyka
    August 19, 2010 at 3:14 pm
    See Todd Kopriva’s blog on the alpha channel / ProRes 4444 bug and workaround:
    ProRes 4444 and ProRes 422 in After Effects CS5
    Walter Soyka
  • Zak Ray
    August 19, 2010 at 3:36 pm
    Wonderful, thanks Walter!
  • Dave Johnson
    August 19, 2010 at 7:35 pm
    Just FYI, Dave, the Animation and PNG codecs aren’t exclusive to Mac Land (nor are any other standard codecs I can think of besides ProRes).
  • Dave Johnson
    August 19, 2010 at 9:09 pm
    You’re definitely talking to the wrong people, my friend … even though I probably spend more time overall in Windows Land, I wouldn’t even think of doing pro video work with source files other than QuickTime, regardless of which platform I’m on at a particular moment.
    Perhaps that’s partially because I started on Macs and still work on both platforms daily, but I think it’s more because several of the folks I learned from stressed the importance of WindowsLand/MacLand dual-citizenship and it’s hard to accomplish that without good use of QuickTime … plus QT just makes the most sense for pro video.
  • Walter Soyka
    August 19, 2010 at 9:31 pm
    [Dave Johnson] “plus QT just makes the most sense for pro video”
    So much production infrastructure relies on Quicktime — it’s just too bad that you have to cross your fingers and hope for the best that the next element in the chain will interpret the gamma correctly! I keep hoping Apple will appoint a Chief Gamma Officer to sort it all out, but I think I’ll be waiting a long time.
    Every now and then I wonder if my work wouldn’t be easier with an all-RGB DPX sequence workflow like Smoke uses.
    Walter Soyka
