Activity Forums Adobe After Effects AE not rendering final comp.
  • AE not rendering final comp.
    Posted by Charles Murphy on February 4, 2008 at 5:38 pm
    Using AE 6.5, I try to render a final composition. It doesnt render any video, i end up getting a file which is about 2 seconds long, and nothing but black screen. The video I’m rendering is only about 20 seconds long. When I try a RAM preview, it says there are no frames to preview, and the render log says this:
    Adobe After Effects v6.5 (Windows) render log for project “title.aep”
    Rendering started on 2/4/2008 at 2:58:29 AM
    2/4/2008 2:58:29 AM: Starting composition “Final”.
    Render Settings: Best Settings
    Quality: Best
    Resolution: Full
    Size: 720 x 480
    Proxy Use: Use No Proxies
    Effects: Current Settings
    Disk Cache: Read Only
    Frame Blending: On For Checked Layers
    Field Render: Off
    Pulldown: Off
    Motion Blur: On For Checked Layers
    Shutter Angle: (From Comp)
    Solos: Current Settings
    Time Span: Work Area
    Start: 0:00:00:00
    End: 0:00:00:00
    Duration: 0:00:00:02
    Frame Rate: 29.97 (comp)
    Guide Layers: All Off
    Storage Overflow: On
    Skip Existing Files: Off
    Output Module: Lossless
    Output To: C:\Documents and Settings\Owner\My Documents\My Pictures\Final_3.avi
    Format: Video for Windows Movie
    Output Info: No Compression
    Embedding: Project Link
    Output Audio: Off
    Channels: RGB
    Depth: Millions of Colors
    Color: Premultiplied
    Stretch: –
    Crop: –
    Final Size: 720 x 480
    Post-Render Action: None
    0:00:00:00 (1): 0 Seconds
    0:00:00:01 (2): 1 Seconds
    2/4/2008 2:58:30 AM: Finished composition “Final”.
    Total Time Elapsed: 1 Seconds
    Log closed on 2/4/2008 at 2:58:30 AM
    Any help would be greatly appreciated as it’s for a project I’m trying to complete. Thanks!
    Thorsten Miess replied 18 years, 7 months ago 2 Members · 1 Reply
  • Thorsten Miess
    February 4, 2008 at 6:34 pm
    Im not sure if im seeing the problem, but its the only thing i can think of in your case.
    -Your work area is to short
    it looks like your work area is set to a to short area:
    Start: 0:00:00:00
    End: 0:00:00:00
    After Effects renders only the work area.
    And also after effects need more than 2 frames to render; in your case there are less than 2 frames.
    To solve the Problem extend your work area by click&drag the end and start of the work area to your end and start for your comp. You can also go to the first frame and hit “B” and then go to the last frame and hit “N”. Then you should be able to see the full video after rendering.
