Activity Forums Adobe After Effects AE not importing layered Illustrator files as layered comps…
  • AE not importing layered Illustrator files as layered comps…
    Posted by Martin Banks on August 21, 2007 at 3:59 pm
    I am having a bit of an odd problem. I’m working on an old G4 15″ Powerbook, in AE6.5 using Illustrator CS2 to make some images, which I am then importing into AE6.5 as layered comps….this works fine.
    However, when I want to do the same on a new macbook pro, using illustrator 10 or CS3 the illustrator document won’t import as a layered composition.
    If anyone can tell me why this is happening and what I can do to stop it I would be very grateful because it’s confusing the hell out of me!!!
    I hope someone can help,
    Many thanks,
    Martin.
    Sando Calrissian replied 19 years, 1 month ago 3 Members · 2 Replies
  • John Dickinson
    August 21, 2007 at 8:16 pm
    If you’d like to send me the file I can test it for you on my system.
    JD
    John Dickinson
    Motionworks
    http://www.motionworks.com.au
  • Sando Calrissian
    August 22, 2007 at 6:26 pm
    Hi Guys,
    I’m actually experiencing the same problem. I’ve been working on this machine for 2 years (G5 running CS2 and AFX 7 – obviously this has been updated from 6.5, but many months prior to this situation arising) and I’ve never before had a problem importing illustrator files or photoshop files into AFX as comps. It’s something thats happened in the last couple of weeks.
    I can open the photoshop files as AFX comps on another identical computer and all the layers appear seperated, but if i import that project onto my machine suddenly the seperate layers just disappear in AFX…
    There must be a setting I’ve somehow selected in AFX. Any ideas folks?
    Thanks guys in advance!
    Sam
