Activity Forums Adobe After Effects AE Not Adding Keyframes Automatically?
  • AE Not Adding Keyframes Automatically?
    Posted by Franz Vorenkamp on August 3, 2010 at 3:12 am
    Hey guys, this is probably a simple one to answer… most likely a key I pressed by accident or something.
    I’m working on a fairly extensive rotoscoping project in Adobe After Effects CS5.
    All day, I’ve been going through and adjusting little things here and there, when all of the sudden it seems like After Effects isn’t automatically adding the keyframes to the time line. I’ll adjust the spline, but no yellow diamond appears on the timeline.
    I’ll have to manually go over and click the Add or Remove Keyframe button every time I make an adjustment.
    It’s not a big deal, but when you’re in the groove, it’s easy to forget to press the add button.
    Anyone know how to get the automatic keyframes back?
    – FMV
    Franz Vorenkamp replied 16 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
