Activity Forums Adobe After Effects AE no vector ….HELP
  • AE no vector ….HELP
    Posted by Alanf071 on September 3, 2005 at 6:45 pm
    I have seen many post about this issue but no answer .
    My after effects 6.5 pro stoped vectorising art work from illustrator.
    When I zoom into quality is worst tham bitmap image .
    It is not timeline , quality switch or OPENGL resolution problem ( I used every resolution and time line switch )
    I use ATI9600 256mb and worked fine till 7 day ago . I upgraded to latest driver but no luck there ,
    Please help coz I have project to finish by this Monday .I know lot of people came across this problem and I would appreciate any suggestion
    Cheers Alan
    Alanf071 replied 21 years ago 3 Members · 4 Replies
  • Steve Roberts
    September 3, 2005 at 10:15 pm
    Is it really vector artwork, and not a raster EPS or AI?
    If it is really a vector file, can you send the file to ads (at) reidroberts (dot) com?
    (Please do not type this address again in another post on the COW.)
    Steve
  • Alanf071
    September 3, 2005 at 11:14 pm
    Steve
    How can I make sure that is real vector , How should I save out AI , I have CS2 version now and everything worked fine before
    I tried saving as AI 10 but no luck EPS and AI .I also have problem with AE type text sometimes shows ok and other times is rasterised
    I think there is problem with my PC .. 🙁
    Thanks for you help
  • Bralo
    September 4, 2005 at 4:25 pm
    Hi Alan
    I had the same problem …my solution was to remove AVID EMP plug in that came with AVID HD on the same machine .
    Remove it and repair install AE
    Hope it helps
  • Alanf071
    September 4, 2005 at 10:10 pm
    Bralo you rule man ..that was it.
