Activity › Forums › Adobe After Effects Expressions › AE move, but convert to 2’s
  • AE move, but convert to 2’s
    Posted by Dale Hayward on March 5, 2009 at 9:06 pm
    hey guys, i have an after effects object with just the position changing & i want to convert it to move on 2’s, but i dont want to change the frame rate of 24 fps. i obviously dont want to hold keyframe every other frame.
    any ideas? i posted this in the expressions area, cuz i thought maybe one could be made, but im really new to expressions.
    thanks!
    d-ale
    Dale Hayward replied 17 years, 6 months ago 2 Members · 5 Replies
  • Dan Ebberts
    March 5, 2009 at 9:46 pm
    Either of these, applied to the keyframed property, should work:
    posterizeTime(12);
    value
    or,
    valueAtTime(framesToTime(Math.floor(timeToFrames(time)/2)*2))
    Dan
  • Dale Hayward
    March 5, 2009 at 9:58 pm
    AH! i almost had it, i was just missing the value part. ok so since im new to expressions, what does the value part mean?
    merci beaucoup!
    d-
  • Dan Ebberts
    March 5, 2009 at 10:43 pm
    That’s just the pre-expression, keyframed(or static) value. In other words, it’s the value you get when you turn the expression off.
    Dan
  • Dale Hayward
    March 6, 2009 at 12:30 am
    hmmm, ok, still don’t understand, but ok thanks!
    d-
  • Dale Hayward
    March 24, 2009 at 3:09 pm
    bizarrely enough, i just switched my project from cs3 to cs4 & the posterizeTime expression dosent want to work any more, even if i redo it all & retype it in. BUT the valueAtTime….. works no prob. Any explanations? expressions are so beyond me
    blog: https://ostrichindustries.blogspot.com/
