[max glascott] “When importing video from an After Effects render, I am forced to pre-render every file in my session every time I make a change…Is this simply a codec issue?”
Probably.
[max glascott] “If i export as pro-res or something of that sort can I avoid having to render at every change?”
If your AE render matches your sequence settings, yes. Just note that if you need transparency, you’ll have to go to ProRes 4444.
Walter Soyka
