Activity › Forums › Apple Final Cut Pro Legacy › AE motion in animation codec into FCP
  • AE motion in animation codec into FCP
    Posted by Audrey Villiard on May 23, 2010 at 12:29 am
    I have exported quick time motions from After Effect. They are in the animation codec. When I read them with Quick Time launcher, they look perfect.
    But when I am importing them into an FCP project using DV/DVCPRO NTSC compression, they glitter (principally the font).
    The problem is that my FCP project needs to be a DV/DVCPRO NTSC because the rest of the footage is in this compression and the export will be done in this compression too.
    What should I do ?
    Thank you,
    Audrey Villiard replied 16 years, 4 months ago 2 Members · 4 Replies
  • Rafael Amador
    May 23, 2010 at 12:05 pm
    [Audrey Villiard] “The problem is that my FCP project needs to be a DV/DVCPRO NTSC because the rest of the footage is in this compression and the export will be done in this compression too. “
    You are forced to render to DV only if you are printing to DV tape.
    If so, try setting Render in High Precision.
    rafael
    http://www.nagavideo.com
  • Audrey Villiard
    May 24, 2010 at 2:57 am
    Thank you for your answer. You are right. It is just that I didn’t want to render all my DV footage and re-render it every time I make changes. But I will continue to do some test.
    Or else, do you know what is the best way to export motion from After effect so they don’t glitter, flick, etc. in FCP ?
    And also what would be the best compression to export the final movie (including mini DV footage mixed with AE motions) for diffusion on DVD, Internet or other ?
    Thank you
  • Rafael Amador
    May 25, 2010 at 4:35 am
    Whatever is your final destination, try to make the best master that you can achieve.
    Whatever is the footage I use I end up exporting to Prores HQ. I set “Render in High Precision” and “Render Motion Effects: BEST”.
    Rafael
  • Audrey Villiard
    May 25, 2010 at 1:35 pm
    O.k. Thanks to both of you.
    I think I will be able to solve my problems.
