Activity › Forums › Adobe After Effects › AE messed up with my file… masks, effects, etc.
  • AE messed up with my file… masks, effects, etc.
    Posted by Franco Andrade on January 21, 2010 at 11:00 am
    Hello!
    Yesterday I was working on AE in a animation with a Illustrator file. I used puppet tool to animate it, some effects and masks. When I finished it, I realized that the “Coninuosly Rasterize” option wasn’t ON, so I turned ON for all layers. Then, I don’t know how, the positions of the things, the masks, the puppet tool settings and the write-on effect was messed, all in diferent positions.
    I thought that this would not be a big problem, because I hadn’t save the file. I closed AE and opened again, and that problem was still in the file!
    Before this happen, I saved several times the project in different files with “Increment Save”. I opened the last one before the problem, and was messed like the other. All the prior files are now with this problem!! HOW COULD THIS HAPPEN??
    I don’t know how this could affect files that I wasn’t using anymore!
    Does anyone know WHY? Or if is possible to fix it, before doing all over again?
    Here is the file:
    https://francoandrade.com/stuff/Cachalot.zip 1.8Mb
    (in the end of the animation, it was supposed to look like the cachalot.ai file!)
    Thanks for your patience for reading this!
    https://francoandrade.com/blog
    Todd Kopriva replied 16 years, 8 months ago 2 Members · 1 Reply
  • Todd Kopriva
    January 21, 2010 at 8:54 pm
    You’ve asked this question on two other forums and gotten answers on both.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
