Activity Forums Adobe After Effects AE Mask Problem
  • AE Mask Problem
    Posted by Lewis Lloyd on September 10, 2014 at 3:04 pm
    Hi there,
    I’m quite the rooky in AE – Just trying to do a screen replacement.
    I started getting this problem when trying to apply a mask, see the
    screenshot – like it’s masking more than the actual mask edges.
    Anyone have an idea what I’m doing wrong here?
    Any help much appreciated, thanks!
    Lewis
    Roland R. kahlenberg replied 12 years ago 3 Members · 8 Replies
  • 8 Replies
  • Doyle Lewis
    September 10, 2014 at 3:12 pm
    what happens if you turn off your corner pin effect?
    Doyle Lewis, Assistant Videographer
    thinkck.com
  • Lewis Lloyd
    September 10, 2014 at 3:24 pm
    Hi Doyle, thanks for your reply.
    That does make the mask work thanks,
    but doesn’t that mean it’s not tracking any more?
    I just want to feather in the edges of my replacement
    screen which i’ve tracked.
    thanks
    Lewis
  • Lewis Lloyd
    September 10, 2014 at 3:46 pm
  • Roland R. kahlenberg
    September 10, 2014 at 4:06 pm
    Your insert layer MUST be the same size as the composition where you apply the Corner Pin tracking data.
    Place the insert layer into another composition and scale the layer to fit the composition size – the CTRL+ALT+F shortcut key does this. Then nest this composition into your ‘final comp’. Then apply your Corner Pin tracking data to this nested comp.
    HTH
    – Roland
    TypeGEMs – the Definitive Type Gizmo for AE
    https://broadcastgems.com/typegems/
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Adobe After Effects CC ACE/ACI
    Imagineer Systems (mocha) Certified Instructor
    https://www.broadcastgems.com/mographintensity_shapestext/
  • Lewis Lloyd
    September 10, 2014 at 5:00 pm
    Thanks a lot for the tips Roland,
    that must have been it, because
    I scaled down the layer to fit into
    the screen.
    Thanks everyone!
    Lewis
    September 10, 2014 at 6:00 pm
    If you need to blur the edges of the insert layer, apply Effect>Blur and Sharpen>Channel Blur AFTER the Corner Pin. Then tweak the Alpha Blur value to taste.
    HTH
    – Roland
  • Lewis Lloyd
    September 11, 2014 at 10:39 am
    awesome!
    September 11, 2014 at 7:19 pm
    WooootS!!!
    – Roland
