Activity › Forums › Adobe After Effects › ae makes dvcpro hd footage grainy noisy why? please help!
  • Michael Szalapski
    June 4, 2009 at 2:00 pm
    What version of AE are you using? And exactly what were your output settings?
    If it’s CS3 I’ll quote Todd from a previous user’s question.
    “Do you have the 8.0.2 update installed? It fixed some issues with QuickTime and gamma-related color shifts.
    Here’s a Technical Support knowledgebase document that should help:
    QuickTime movies exported from After Effects CS3 are darker or lighter tha… ”
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Anthony Le
    June 4, 2009 at 10:30 pm
    THANK YOU MICHAEL! I believe I’ve figured it out. I have cs4 but I went ahead and read through the documentation you linked anyways. I found that enabling the “Match Legacy After Effects Quicktime Gamma Adjustments” under project settings did the trick. Now the footage inside AE and after export from AE matches the raw footage very well. Thanks a ton for pointing me in the right direction.
  • Michael Szalapski
    June 4, 2009 at 11:57 pm
    You’re very welcome. That is why we’re here.
    – The Great Szalam
