AE Make Movie slows down as render progresses
I have an issue with After Effects and I’m not sure if it’s just the way it works or if there’s a tweak that might fix it. I’m trying to render a 15 minute movie. I click on Make Movie and hit render and it starts out fine, but as the process continues, the performance slows down. The estimated time goes up. About an hour in and it’s almost stopped altogether. Each frame is taking 10 times as long as it took to render when I first started.
I’ve tried a bunch of stuff in the preferences — tweaking the memory/cache preferences, purging frames in the secret menu, etc…
It doesn’t seem to matter how I set up the preferences. Am I missing something?
I’m running a G5 ppc Dual 1.8 with 3gb of ram.
Adobe After Effects CS3Is it normal to slow down like that as rendering continues? It’s not as if the composition changes as it progresses. There are no new layers / elements involved.
Thank you,
Tom
