Activity Forums Adobe After Effects AE Lower Thirds Opacity and Alpha channel problem
  • AE Lower Thirds Opacity and Alpha channel problem
    Posted by Dave Brown on February 12, 2015 at 2:48 am
    Hello anyone,
    I’ve purchased a couple lower third templates for After Effects for using in my live stream broadcast.
    I’ve changed colors, added my logo, changed text etc. I can export in Pro-Res and the titles look great on the computer and in Premier. Problem is when i export them and stream them through the DSK function (luma key mode) on my Roland V-40HD i lose the varying degrees of opacity.. in fact everything is solid and the gradations of green seen in the example at 21:29 aren’t there, they become gradations of grey.. also the red box behind the name of the Commissioner is supposed to be set to %60 opacity.
    please check Port Commission Meeting lower third at 21:29
    https://www.youtube.com/watch?v=abH1ZoKhag4
    Also, notice the nasty jagged edges that show up.. they aren’t there when i composite on my computer. I really need these transparencies to work live and to avoid these horrible edges i’m seeing.
    Can anyone help me with this?
    thanks
    Dave Brown replied 11 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
