  • Chris Smith
    July 19, 2006 at 4:22 pm
    There is the loopout expression or you can take your BG, back it up halfway. Copy the layer. On the copy move it forward halfway then animate a opacity dissolve between the two layers in the middle where they meet. Then render this out. Bring back in and set the footage to loop in the loop options.
    Chris Smith
    https://www.sugarfilmproduction.com
