Activity Forums Adobe After Effects AE lighting w/ Trapcode monitoring problem
  • AE lighting w/ Trapcode monitoring problem
    Posted by John Czerwinski on February 21, 2008 at 4:31 pm
    I am working on a 3D images (i.e. illustrator, photoshop, and a green screen of talent walking towards the camera) project using AE lighting with Trapcodes Lux plugin. The problem I am having is with monitoring what I am see on the active camera in AE and the NTSC monitor. I created 6-7 spot lights on the scene and everything looks fine on the active camera and NTSC monitor, but I when render out a movie everything is black except where the spots are. I added an ambient light to the scene and renders looks fine, although I can not see a difference when I change the intensity of the ambient light. Why would the active camera and NTSC give a look of an ambient light on the scene when I did not use one in the first place?
    Using AJA Io box for viewing on NTSC monitor
    Thank you,
    John
    John Czerwinski replied 18 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
