Activity Forums Adobe After Effects AE Keyboard Editor Bug ? 15.1.2 (2018)
  • AE Keyboard Editor Bug ? 15.1.2 (2018)
    Posted by Alan Eddie on October 9, 2019 at 11:00 am
    Version 15.1.2 (2018)
    Hi there, I am having a frustrating issue, moving from AE 2014 to 2018. I am manually setting up shortcuts as I like them in the new editor.
    The issue is for some commands, if I remove the short cut, the command disappears after I save the keys. So if I assign “Take snapshot 1” to nothing and save the keys and reopen editor, that command disappears!
    Even when I go into the text file, I can see that the line has been removed! Furthermore I can see that
    AppData\Roaming\Adobe\After Effects\15.1\aeks\After Effects Default.txt = 27.5kb
    AppData\Roaming\Adobe\After Effects\15.1\aeks\AlanEddieKeys2.txt = 21kb
    So as I unassign a command it is actually deleting the line from the keyboard shortcut file, which disables the command from appearing in the shortcut editor!
    Am I missing something obvious or was this a known bug?
    Thanks for any pointers.
    A
    Alan Eddie
    ___________________________________________
    3d Animation + VFX + After Effects Scripting
    alaneddie.com
    aescripts.com/authors/a-b/alan-eddie/
    Alan Eddie replied 6 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
