Activity Forums Adobe After Effects AE keeps freezes during rendering
  • AE keeps freezes during rendering
    Posted by Mit Panchani on September 4, 2016 at 9:49 am
    Source File : MP4
    Length: 0:04:47
    PC specs: 16 GB ram
    AAE CS6
    Output : AVI
    Problem:
    I ran rendering twice, and both time AAE froze just around 7500±100 frames. Output file is around 40GB when the program freezes.
    It has in total 8500 frames.
    I have allocated 12GB of RAM for the AAE.
    After the program freeze, I cant force stop the program and I have to hard reset the desktop to make it stop.
    Is the footage is culprit here?
    Mit Panchani replied 9 years, 12 months ago 3 Members · 5 Replies
  • Roei Tzoref
    September 4, 2016 at 10:25 am
    1. What Ae and OS version exactly (decimal points please)
    2. When you Preview your footage at full quality in Ae in the problem area, does it work fine?
    3. I would render a Png Sequence so that you won’t have to Re-Render all over again. when Ae is stuck on these offending frames you should check what exactly is going on there because it often is a currupt frame of Video/3D/Other type of sequence. if it’s all Graphics/Native Ae material I would examine the workflow and set the effects in a different way to see what exactly is causing this
    4. Purge Cache memory: edit->purge->all, and also in the preferences under media and disk cache
    5.Reset your preferences
  • Walter Soyka
    September 4, 2016 at 11:22 am
    [Roei Tzoref] “I would render a Png Sequence so that you won’t have to Re-Render all over again. “
    PNG is lossless and gives generally small files, but its also the slowest image format to compress. If speed matters more than disk space, use a different format like DPX, PSD, TGA, or TIFF.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Mit Panchani
    September 4, 2016 at 12:14 pm
    1. AAE 11.0.2.12 and OS WIN 7
    2.It works fine
    I just added background music , I have not added any animations in this video edit.
  • Roei Tzoref
    September 4, 2016 at 12:21 pm
    this is not the latest update of it’s release. first you should update your software to 11.0.4 look here: https://blogs.adobe.com/creativecloud/after-effects-cs6-11-0-4-update-bug-fixes/
    after you have reset your preferences and cleared the cache, if it’s not all these 3 things – it could be a corrupted frame in your video or audio that’s causing this. if your music is Mp3, I would convert it to WAV, and re-import it and try again. if this does not work – I would convert your video to lossless version (QT Animation for example) and re-import it and try again.
  • Mit Panchani
    September 4, 2016 at 1:07 pm
    Thanks for the help. I shall update it and see further
