Activity › Forums › Adobe After Effects › AE keeps crashing + Dynamic Link problems
  • AE keeps crashing + Dynamic Link problems
    Posted by Brett Dejager on December 21, 2009 at 7:00 pm
    Hello all!
    I’m having a very frustrating time with my CS4, After Effects. I try to use the dynamic link function between my premiere pro and after effects but it always freezes then crashes. When I re-open my AE project it says “missing X amount of files” and my whole project is that rainbow colored logo. After I replace all the footage, it will crash again once I move around the timeline. I’m running windows 7 with only 2GB RAM. What do you think the issue is? Am I doing something wrong? Thanks in advance.
    Michael Szalapski replied 15 years, 3 months ago 5 Members · 8 Replies
  • 8 Replies
  • Brett Dejager
    December 21, 2009 at 8:40 pm
    Thanks for the quick response. That’s what I was afraid of. Although it shouldn’t be the cause of my dynamic link problems (I wouldn’t think). Do most people import the whole premiere pro project into the after effects to do the FX or just particular clips/scenes?
  • Michael Szalapski
    December 21, 2009 at 8:44 pm
    Dave’s right; you need a lot more RAM. (You didn’t mention what kind of processor you’re using…but you definitely need more RAM)
    Until then, turn caps lock on before you open AE and start linking files. Once everything’s linked change your composition to quarter resolution THEN turn caps lock off. That may or may not help you.
    HOWEVER, considering your teeny tiny amount of RAM, I would suggest that you NOT dynamically link your Premiere project in AE. Instead, import the Premiere project into AE as a composition. It’ll use a lot less RAM and is much less likely to cause issues.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Brett Dejager
    December 21, 2009 at 8:51 pm
    Thanks for the advice! My comp runs on a AMD Phenom II X4 965 Processor 3.41 GHz. RAM sounds like my next required purchase. Also, I’ll no longer try to dynamic link it!
  • Brett Dejager
    December 21, 2009 at 9:26 pm
    My processor is good enough to run CS4 although my RAM is embarrassing! Easy fix though.
  • Daniel Ramirez
    December 22, 2009 at 10:34 pm
    Indeed, 2GB just isn’t enough for Dynamic Link.
    Dan Ramirez
    After Effects
    QA Engineer
  • Alexander Nanni
    March 29, 2011 at 7:28 pm
    hi um i have cs4 and it keeps crashing like right when i start up it keeps saying somthing about parting then it closes thus i cant use it i need help. thanks
  • Jennie Davis
    June 24, 2011 at 9:44 am
    hi, i’ve had the same problem, it crashes once i move the timeline. but i’m using illustarter files. i tried the caplock and it worked (so far), i’m using 4 ram. are the vector files so heavy? or is it a diffrent problem then to the trouble the with premier? how can i make the illustrater files lighter so it won’t crash?
  • Michael Szalapski
    June 24, 2011 at 1:24 pm
    If you’ve got any high-res raster graphics embedded, they can add make Illustrator files rather unwieldy. You might check to make sure that you’ve got your RAM settings set up correctly.
    – The Great Szalam
