Activity Forums Adobe After Effects AE into FCP – Mixed footage
  • AE into FCP – Mixed footage
    Posted by Michael Nielsen on November 11, 2008 at 2:42 am
    I am having problems importing footage from after effects into FCP. When I do the imported footage is jittery. The AE material is 1280 x 720, sq. px, 23.98fps. The FCP project is 1280 x 720, sq. px, 23.98fps, using the Apple ProRes 422 compressor.
    Is it a problem with how I am compressing the footage from AE? Is there something obvious I’m missing?
    Thanks.
    Michael Nielsen replied 17 years, 9 months ago 2 Members · 4 Replies
  • Mark
    November 11, 2008 at 11:36 am
    I would have to see your render settings in AE, and not just the comp settings… One thing that I notice is that your comp is set to half res, which is fine, this is just for previews in AE and allows you to work faster….but, make sure in the render settings you are using Full resolution as the output. Also, are you rendering out to 23.976, or are you rendering out to 29,97 with a pulldown ???? All important questions. One more thing, are you properly interpreting the footage and fields etc of the footage that you are bringing into AE ???
    Mark
    Mark Harvey
    Senior Editor
    Le Réseau des sports
  • Michael Nielsen
    November 11, 2008 at 12:42 pm
    Hi Mark,
    I am rendering out the project at full resolution, and I am rendering at 23.976 and not 29.97. Which should it be? And as for the footage I’m working with in AE, it is all still footage that I am adding motion to, so there is nothing to interpret on that end.
    I’ve attached my render settings. Thanks for your help.
  • Mark
    November 11, 2008 at 1:51 pm
    Unfortunately, I am not too familiar with the ProRes codec…I am an Avid dude….but could you not render out of AE back into the ProRes codec.
    Also, when you say that it is all footage that you are adding motion to, what excatly does this mean ??? If you are bringing footage from FCP into AE, then you still need to make sure that it is being properly intepreted by AE…maybe AE is deinterlacing, and shouldn’t be….
    Mark
    Mark Harvey
    Senior Editor
  • Michael Nielsen
    November 11, 2008 at 3:41 pm
    I think I have figured it out. I rendered the AE footage back out as 29.97 material in the Apple ProRes codec and so far it is smooth. I am not importing FCP footage into AE and rendering it back out, but rather adding motion to still photographs that are then being put into a FCP project and mixed with live footage.
    Either way, so far it works. Thanks again.
    Michael Nielsen
