Activity › Forums › Maxon Cinema 4D › AE Integration?
AE Integration?
Posted by Jason Linn on June 24, 2006 at 9:41 pmok, so I saved my project in cinema 4d to a .aec file, but after effects 7 won’t let me import it. When I go to the import menu, it’s greyed out. Any sugguestions? thanks!
~Jason
Powermac G5
dual 2.7 GHZ
8 gig. of ram
After effects 7
Cinema 4d 9.1Jason Linn replied 20 years, 1 month ago 2 Members · 8 Replies -
Adam Trachtenberg
June 25, 2006 at 4:12 amCopy the AE 6.5 plugin from your Maxon>Exchange Plugins folder to your AE plugins folder.
Jason Linn
June 26, 2006 at 10:34 pmAlso, when I import this into AE, it makes the comp, but the actual file is jsut a picture of color bars.. do I need to rener it? if so, how?!
thanks!
~Jason
Adam Trachtenberg
June 26, 2006 at 11:01 pmYes, you have to render–otherwise there’s nothing for AE to display, right?
Adam Trachtenberg
June 26, 2006 at 11:02 pm[tweekskratch] “do they have a plugin for AE 7?”
Not yet, but the 6.5 plugin works. -
Jason Linn
June 28, 2006 at 12:21 amid “render view” the same as a normal render, or is a render more like an export? and a render view is like a single frame render? sorry I’m a newbie.
thanks! -
Adam Trachtenberg
June 28, 2006 at 1:07 pm[tweekskratch] “id “render view” the same as a normal render, or is a render more like an export? and a render view is like a single frame render? sorry I’m a newbie.
thanks!”Render editor view is a still frame–used for test rendering. It’s very similar to the Picture Viewer render, but some parametric objects give you options for using lower quality for editor rendering. The hyperNURBS object is the big one to keep an eye on there.
Rendering to the Picture Viewer gives you the ability to export, whether to still frames or movie files.
