Activity Forums Adobe After Effects AE footage not Full Resolution
  • AE footage not Full Resolution
    Posted by Mark Palmer on May 26, 2006 at 8:31 pm
    When importing some footage into AE that I recorded on a videocam it looks pixelated, even at Full resolution. The pixilation is not bad, but looks like about half resolution. It does not look pixilated when I inspect it in Quicktime or FCP. When I render the footage in AE, it comes out similarly pixilated. What do I have to do to remove the pixilation? Other footage I import into AE does not have this problem.
    Mark Palmer replied 20 years, 3 months ago 3 Members · 8 Replies
  • 8 Replies
  • Alistair Liddell
    May 30, 2006 at 4:45 pm
    is the footage DV if so are you just looking at the DV artifacts?
  • Mark Palmer
    May 30, 2006 at 5:21 pm
    I recorded on a JVC DV500 and transferred using a Sony Video Walkman into FCP. Maybe I had a setting on 1/2 resolution? I don
  • Enzo Tedeschi
    May 31, 2006 at 5:44 am
    Have you checked the “/” quality sertting box in your layer settings?
    Could you post a screenshot?
    Enzo Tedeschi
    ____________________________
    Editor
    Sydney, Australia
  • Mark Palmer
    May 31, 2006 at 5:57 am
    I don
  • Mark Palmer
    May 31, 2006 at 6:01 am
    (This image is with layer quality set to Best.)
  • Enzo Tedeschi
    May 31, 2006 at 6:32 am
    Looks like it could be an interlacing issue to me…
    I had tapes come back looking like that once – the DOP had shot some weird ‘progressive’ mode (not really) that gave us 1-field instead of two – effectively 50% resolution as you say.
    Not saying that that is what is happening here, but it look similar to my eyes. Check the ‘interpretation’ of the QT in AE, and make sure your field order is around the right way…
    See if that helps?
    Enzo Tedeschi
    Editor
    Sydney, Australia
  • Mark Palmer
    June 1, 2006 at 6:07 pm
    Okay, I
  • Mark Palmer
    June 2, 2006 at 6:13 pm
    This is a last-ditch attempt to get my question answered. Hopefully these clips will clarify the problem.
    Here
