Activity Forums Adobe After Effects Expressions [AE extend script] how to add expression to hidden ‘audio levels’ property
  • [AE extend script] how to add expression to hidden ‘audio levels’ property
    Posted by Emid Rianta on October 20, 2020 at 5:49 pm
    i made script to create a new comp and add expression to audio levels. but as you know in the timeline, new comp has no audio so the ‘audio levels’ property is hidden.
    any idea/trick how to solve this?
    Emid Rianta replied 5 years, 11 months ago 2 Members · 2 Replies
  • Filip Vandueren
    October 21, 2020 at 10:53 am
    You can add a “Audio -> Tone” Effect to the comp-layer.
    This will force the layer to generate audio and reveal the audio levels property.
    After you’ve assigned your expression to the audio levels, it is safe to remove the Tone effect.
    The audio levels property will be hidden again, but the expression will remain in place for when the pre-composition gets sound again in the future.
    Alternatively, just keep the tone effect but set its Level parameter to 0%
  • Emid Rianta
    October 21, 2020 at 1:31 pm
    Thats work!! the expression was still remain in place! Thank you Filip u get the hell out of my head xD
