Activity › Forums › Adobe After Effects › AE Expression – Source text based on main comp time
  • AE Expression – Source text based on main comp time
    Posted by Kristine Jones on July 28, 2022 at 5:14 pm
    I’ve created a one hour countdown timer. At the start of each minute I’d like to transition to a different background for 5 seconds then transition out. This new background requires a change in the timer’s text color.
    To achieve this I’ve created a precomp with the new background and a duplicate of the timer text layers with text recolored. Ideally I’d like to reuse this single comp multiple times on top of the main timer, instead of creating a new precomp for each minute’s change.
    Within the precomp I’ve changed the source text expression to: comp(“countdown”).layer(“00”).text.sourceText;
    This gives me the text I want to see, but from the beginning of the main countdown comp. If my precomp is located at X min on the main comp’s timeline, what code would I add to display the text at that point in time?
    Graham Quince replied 4 years, 1 month ago 2 Members · 1 Reply
  • Graham Quince
    August 3, 2022 at 9:39 am
    Expressions in AE run every frame – so what’s needed is an IF statement to check the value of the source text – and when the source text displays a value within 5 seconds of each minute, then run that colour change function.
    Something like:
    var mins = parseInt(time/60);
    var secs = parseInt(time)-(mins*60);
    var col = "#FF0000";
    if (secs < 6 || secs > 55) {
    col = "#00FF00";
    hexToRgb(col)
