Activity Forums Adobe After Effects Expressions AE expression: During Marker Duration Layer Opacity 100, End marker Opacity 0.
  • AE expression: During Marker Duration Layer Opacity 100, End marker Opacity 0.
    Posted by Craig Trayler on March 3, 2022 at 2:30 pm
    Hi all,
    I tried searching with no luck, so hopefully someone can assist.
    I have seen expressions linked to markers with set names “In””Out”, but I would like an expression that would be something like:
    Start and for the duration of markers length, layer opacity = 100%.
    After marker ends, opacity = 0%.
    So that the gap in-between the end of the last marker and before the start of the next marker the layers opacity will be 0%/Off, and during the markers, the layer will be 100%.
    Thanks in advance for any help.
    Craig
    Craig Trayler replied 4 years, 6 months ago 2 Members · 2 Replies
  • Dan Ebberts
    March 3, 2022 at 3:48 pm
    Something like this maybe:
    m = marker;
    val = value;
    if (m.numKeys > 0){
    n= m.nearestKey(time).index;
    if (time < m.key(n).time) n--;
    if (n > 0){
    t = time - m.key(n).time;
    val = (t > m.key(n).duration) ? 0 : 100;
    }else{
    val = 0;
    val
  • Craig Trayler
    March 4, 2022 at 12:21 pm
    Dan! Perfect! Thank you soo much!
