AE exports out.
Here is the problem, I am compositing a rendered passed 3d. I composed the materials in ae cs3 using it’s actual pixel ratios and format. I add it to the render queue, as a quicktime .mov (since I a using final cut), as animation and straight alpha render. Now here is the problem, When put it in FCP, the materials looks pixeled, the edges are jaggy most of the details are lost, and it seems low res in an Sony HDMI Monitor. I have changed the sequence codec to an rgb out. I am still getting that problem.
What am I a doing wrong??
