Activity › Forums › Adobe After Effects › AE error message
AE error message
Posted by Robert Bec on August 26, 2006 at 5:57 amhi there
the message reads
After Effects error: OpenGL:Failed to generate shadow map
i cant use openGL without getting this message
thanks
Robert
Mylenium replied 20 years ago 2 Members · 5 Replies -
Mylenium
August 26, 2006 at 10:38 amAre you sure your graphics card is set properly and supports all OpenGL features AE uses? Most likely it has too little VRAM to accomodate the shadow maps.
Mylenium
[Pour Myl
Mylenium
August 26, 2006 at 1:48 pmVRAM –> Video RAM. Since you have a 7900, that should be way enough. Still, check if you are using the correct OpenGL application setting in your NVidia menu. AE’s config is quite unique and the default settings (or settings from other 3D apps) don’t work too well.
Mylenium
[Pour Myl
Robert Bec
August 26, 2006 at 9:18 pmHi Mylenium
these are the settings within AE
Adaptive resolution limit – 1/4
Accelerate effect using – Adaptive resolution
texture memoery – 95mb
quality – more accurateand OpenGL box is ticked
what do you think
Robert
Mylenium
August 27, 2006 at 10:21 amNo, I mean the graphics card settings. There are special OpenGL settings for many apps in the NVidia driver. You may need to set them accordingly.
Mylenium
[Pour Myl
