Activity Forums Adobe After Effects AE Error Message Help!
  • AE Error Message Help!
    Posted by Mark Dalzell on March 2, 2008 at 8:38 pm
    Hi Guys,
    I’m new to AE so please bear with me. I have seen this error message a few times and don’t know quite how to deal with it.
    “Unable to allocate space for 720×540 image buffer. You maybe experiencing fragmentation. In the memory/cache preferences, dialog box, try decreasing the maximum RAM cache size value an dselect the enable disk cache option, increasing maximum memory usuage or both”.
    I’m using CS3. Under the Memory/Cache Page I have it set as:
    Maximum memory used: 60% = 1.2 GB
    Maximum RAM caches size: 60% = 1.2 GB
    Enable Disk Cached IS CHECKED.
    Maximum disk cache size: 2000MB
    Prevent DLL address space fragmentation IS NOT CHECKED.
    Any help would be greatly appreciated.
    Regards.
    Mark Dalzell
    PC Specs:
    • DAW I:
    VisionDAW 4U 8-Core Xeon Workstation
    2 Intel QUAD-Core Xeon 5365-3.0GHz, 8MB, 1333MHz Processors
    4GB 667MHz Fully Buffered Server Memory Modules (2x2GB)
    WDC 250GB, Ultra ATA100, 7200 rpm, 8MG Buffer Main OS HD
    MOTU 24 I/O (main) / MOTU 2408mk3 (slave)
    2 WDC 750GB, SATA II, 7200 rpm, 16MG Buffer HD
    Plexor PX-800A 18X Dbl. Layer DVD+/-RW Optical Drive
    Front Panel USB Acess
    Integrated FireWire (1394a) interface
    Noise Prevention 600W PFC Power Supply
    2 WD Raptor 150GB Data Drives
    3xUAD1 Universal Audio Cards
    Windows XP Pro
    Matrox Parhelia AVPe Dual Head Graphics Card,
    Dual 17″ Samsung LCD Monitors
    Jack Watts replied 18 years, 6 months ago 2 Members · 1 Reply
  • Jack Watts
    March 3, 2008 at 2:46 pm
    Ive run into this problem myself. I also have 4 gig ram and From my understanding After Effects can only register 2GB of ram unless you turn on multiprocessor support under preferences! (this could be incorrect,if so some please tell me). Windows XP [if 32bit] will only recognize 3gb of ram. How i solved this was setting my maximum memory usage to 60% and ram cache to 50%. Under media cache preferences i delete the cahce folder on a regular basis. If you allocate to much ram memory after effects will freze because it doesnt know how to handle it.Again with multiple core processors as with the ram issue your OS might have trouble acknowledging each core individually and try recognizing them as one collective unit thus freexing your system! and causing relative programs to promt memory errors,You might have to manually configure your system to recognize all cores! Its best if you just tweak your seetings until the msg stops being prompted and you are happy with the relative rendering time for you workflow! As i said this is my opinion based on my experiences and i could be wrong!
