Activity Forums Adobe After Effects AE error: file damaged.
  • AE error: file damaged.
    Posted by Steve Morris on May 5, 2007 at 4:24 pm
    I had just finished rendering last night and was in the process of shutting down when the power went out. I tried to open the file this morning and it does not open. I get the following errors.
    AE error: file damaged (33::7)
    AE warning” unable to read project color setting. Color setting reset to factory defaults
    I had a days work in to the project and did not have a back up yet.
    Is there anyway to recover the file?
    I replaces the preferences without any luck.
    Using AE7 on a PC
    David Cediel replied 11 years, 12 months ago 3 Members · 3 Replies
  • Darby Edelen
    May 5, 2007 at 5:44 pm
    The only option I’m aware of that works sometimes is creating a new project and trying to import your corrupted one into it. I’ve had mixed results with this over the years.
  • Steve Morris
    May 5, 2007 at 9:02 pm
    Good idea. I now remember reading about this in the past. I went ahead and tried it. It did not work for me. I will remember it for the future.
  • David Cediel
    September 26, 2014 at 4:11 am
    como es esa opción que no la entiendo
