Activity › Forums › Adobe After Effects › AE Error: Failed to acquire CFM version of suite ADM Basic Suite, Version 5 (48::0)???
  • AE Error: Failed to acquire CFM version of suite ADM Basic Suite, Version 5 (48::0)???
    Posted by Rob Sankey on April 14, 2006 at 5:18 pm
    I’ve been getting this error message ever since upgrading to AE7. Has anyone seen this before? I’m not sure which plug-in this is referrring to escpecially since all of my plug-ins seem to be working properly.
    Thanks in advance,
    RS
    Rob Sankey
    Andrew Yoole replied 20 years, 5 months ago 3 Members · 4 Replies
  • Mylenium
    April 14, 2006 at 5:48 pm
    Mmh, even if you say otherwise, it must be one of your plugins. I’m no programmer, but the message would point to some plugin not being able to read data in the render queue. Have you watched the renderqueue with twirled down extended info? This should give you a clue which layer (and the effects applied thereon) might cause this.
    Mylenium
    [Pour Myl
  • Rob Sankey
    April 14, 2006 at 5:51 pm
    Good thought. The problem is that I get this message when I launch AE. I hit the enter key a few times and then it launches properly. I don’t think it has anything to do directly with the render que.
    RS
    Rob Sankey
  • Mylenium
    April 14, 2006 at 5:55 pm
    Mmh, if it pops up even on startup (while AE is scanning for plugins), then definitely something is wrong. This would indicate that multiple plugins are affected which in turn could only be some plugin suite like Boris or similar.
    Mylenium
    [Pour Myl
  • Andrew Yoole
    April 15, 2006 at 3:26 am
    In my case this message was caused by some Digital Anarchy plugins that needed upgrading for AE7.
    Adobe addresses the issue here:
    https://www.adobe.com/support/techdocs/332536.html
