Activity › Forums › Adobe After Effects › AE Error 86 :: 2
AE Error 86 :: 2
Posted by Ryan Odenthal on November 23, 2010 at 2:41 amEvery time I attempt to render I receive this error. It happens at the exact same time every time I render. I’ve tried turning on and off multi core processing. Turning on and off OpenGL. Also, replacing the footage. I really need to get this render going. Any suggestions?
Justin Zeising replied 7 years, 11 months ago 4 Members · 9 Replies -
Chris Wright
November 23, 2010 at 3:58 amthose error codes are usually from h.264 or some other interframe compression. transcode to prores or quicktime png before importing into ae and it should work fine. also, when rendering, image sequences don’t force you to start from scratch. pretty nice.
https://technicolorsoftware.hostzi.com/
Todd Kopriva
November 23, 2010 at 4:28 am> Also, replacing the footage
This problem normally arises because of a specific footage item. But you say that you’ve tried “replacing the footage”. Please conform that.
Also tell us what version of AFter Effects, what operating system, what kind of footage, what you’re rendering and exporting to, and so on.
Also, confirm that you’ve applied the most recent After Effects update.
Technical Support for professional video software
After Effects Help & Support
Premiere Pro Help & Support
Ryan Odenthal
November 23, 2010 at 2:05 pmI can confirm that I have replaced the footage with it self, I now realize how dumb I am not to of tried replacing it with something else. I’m going to try that now. I’m running CS5 (10.0)on Windows 7 Ultimate. i’m working with H.264 .MOV files that have been previously chroma keyed in AE. In attempts to root out this error, I’m rendering with multicore processing, and openGL disabled. I am rendering this composition in H.264.
Todd Kopriva
November 23, 2010 at 5:24 pm> I’m running CS5 (10.0)
Install the After Effects CS5 (10.0.1) update. That update fixes a lot of problems.
Ryan Odenthal
November 24, 2010 at 2:07 pmOkay, then I’m now rendering it in Quicktime. I’ve installed 10.0.1 and then error is still there. When the error happens, all compositions become unreadable. And if it matters happens at 1:45 out of 3:00 every time I render. I’m using plug ins such as digieffects old film, sure target 2 and twitch. I have tried reinstalling twice. I’m out of ideas.
Todd Kopriva
November 24, 2010 at 4:50 pmIt seems that there is a specific seciton of a specific footage item that is causing this problem. Have you determined which source file is casuing the problem?
Ryan Odenthal
November 25, 2010 at 2:01 pmThe thing is is that it seems to error around one of the .mov files, in which every single clip then becomes unreadable and no matter how much I replace the items, it still errors at that exact same time. And each time it claims to not be able to read a different file. I have tried reinstalling, and I don’t know what I can do.
Justin Zeising
September 30, 2018 at 6:24 pmHey … i have another Problem and i thought u could know that … Everytime i try to track a video so i can put a 3d text it says “Unknown process exception” like 5-10 seconds after. Do u know how to fix that ?
