Activity Forums Adobe After Effects AE embedded color profile
  • AE embedded color profile
    Posted by Sascha1979 on May 2, 2005 at 5:05 pm
    hi folks.
    I have a problem importing a .tif with embedded (ECI-RGB.icc) color profile in after effects.
    the color in after effects looks different than in photoshop.
    any idea to handle this problem.
    I already tried to save the .tif as a .psd without embedded color. but the effect was the same.
    the image less saturation…
    thx 4 help
    Sascha1979 replied 21 years, 4 months ago 3 Members · 3 Replies
  • Barend Onneweer
    May 2, 2005 at 5:36 pm
    Is the Color Management in Photoshop enabled?
    AE doesn’t have any Color Management, and if it’s enabled in PS, you’ll see a difference.
    Bar3nd
  • Filip Vandueren
    May 2, 2005 at 5:53 pm
    You should use Photoshop without any Color Management.
    Even if a file doen’t have profile assigned, it’s possible that Photoshop still alters the way the file is viewed on your monitor.
    In Photoshop open the Color Settings window (Command-Shift-K or Ctrl-Shift-K for PC)
    Select Color Management Off
    Working Space RGB should be set to Monitor RGB
    There’s some discussion about After Effects (non-existing) Color Management options in Chris&Trish Meyers’ book:
    “Creating Motion Graphics with After Effects: Volume 2: Advanced Techniques”
    They offer a plugin on the cd that can do Profile conversions inside After Effects:
  • Sascha1979
    May 3, 2005 at 9:55 am
    thanks
