Activity Forums Apple Final Cut Pro Legacy AE effects going to 35mm – edit in FCP
  • AE effects going to 35mm – edit in FCP
    Posted by Andrea Mino on December 1, 2008 at 9:59 pm
    Hi all, not sure if this is the place to post this but if not hope somebody has some tips/opinions that can help.
    We are working on two features shot with the P2 (1920×1080 24p). Right now both films are in the visual effects part of the process, the people that are in charge of that are using AE to get some 2D done and some basic masking, like erasing booms and stuff.
    For all of us, this is our first experience working on a feature shot with the P2, and first on a feature that’s gonna end up on 35 mm, which is making us wonder if the AE workflow is the appropriate one.
    I’m the one editing it, so, my workflow to get to them the footage has been, in one case, giving them the quicktime that were exportd from the P2 and the Firestore and on a separate document the In-Outs of the used portions, in other cases, exporting the clips from Final Cut with NONE compression and just with some 15frames of head and tail. The reason for that was cause when working with PC the clips imported from the P2 and Firestore won’t open. (we just have the quicktimes not the content folder with the .txt file original of the P2)
    I assume that so far both workflows work, maybe one is better than the other in terms of handling the footage in AE (faster, easier), but in terms of losing resolution or something like that, i think both process are compression free. If i’m wrong please correct me.
    So, now, that the effects need to go back to the original edit i’m assuming that exporting from AE to FC the product should be set on compression NONE to not lose resolution, instead of using Sorenson or Animation, or some other codec.
    This is were we are not certain of our workflow.
    We will be happy to hear other people’s expertise in the area. Is our workflow correct, or just good enough, or just plain a mess?? and what is the best output from AE to have the movie and effects as crystal clear as possible the moment of the blowup??
    Thanks much
    Rafael Amador replied 17 years, 9 months ago 2 Members · 3 Replies
  • Rafael Amador
    December 2, 2008 at 1:54 am
    [Andrea Mino] “exporting the clips from Final Cut with NONE compression”Hi
    Hi Andrea,
    I think you could have choose a better option than NONE.
    NONE is the codec that makes the bigger files in earth without adding no advantage.
    30 MB per second for 8b RGB. Animation gives you the same for 20 MB per second.
    And if you are willing to pay some money, you have Sheer that takes some 12 MB ps or Microcosm that makes 6.6 MB ps files, all loseless Those two codecs are cross-platform and you need to pay the compressor but the reader is free.
    Another solution is ProRess now that there is a free reader for PC, and you keep in 10b YUV instead of 8b RGB. Or you can even try with the AVID codecs that are free.
    Cheers,
    Rafael
    http://www.nagavideo.com
  • Andrea Mino
    December 2, 2008 at 8:01 pm
    Hi Rafael, thanks for your reply, so based on what you say there are no difference in the final output if I export with NONE or, lets say, Animation? It is true that NONE gives me huge files but what about compression and resolution, do i lose any if exported with something else?
  • Rafael Amador
    December 3, 2008 at 11:26 am
    Hi Andrea,
    NONE, Animation, Sheer 444 and Microcosm, the four are “lossless” codecs so you will always recover the original RGB information of each pixel of the picture.
    The last three codecs are compressed. This doesn’t mean any loose in quality, just means that the file is optimized to take the smaller possible size. Is just a matter of packing the same information in a more efficient manner.
    You should have a look to this:
    https://codecs.onerivermedia.com/
    Rafael
