Activity Forums Adobe After Effects AE doesn’t see Media Encoder — need to export H264
  • AE doesn’t see Media Encoder — need to export H264
    Posted by Jerel Peterson on December 20, 2021 at 4:19 am
    I need to export using something that will give me smaller file sizes than ProRes, etc. I found tutorials about how to use H264, but whenever I try to add to Adobe Media Render Que, it says that Media Encoder is not installed–but it is ! I use it in Premiere all the time. I just updated it to see if that would make a difference, but it doesn’t. AE keeps telling me it’s not installed.
    Any suggesstions?
    John Fishback replied 4 years, 8 months ago 4 Members · 3 Replies
  • Tero Ahlfors
    December 20, 2021 at 6:28 am
    Have you updated AE along with Premiere? All of those programs should be around the same release versions for the programs to see each other.
  • Eric Santiago
    December 20, 2021 at 2:03 pm
    There is a long-running issue with AME and the rest of the Adobe (associated) Apps.
    I just ran into it again with CC2021. I have to roll back to 2020 to use any AME workflow.
  • John Fishback
    December 20, 2021 at 4:56 pm
    I have no idea why this is happening, but a workaround would be to export a master file from AE (using the same codec as the source media) and use that in Media Encoder.
