Activity › Forums › Adobe After Effects › AE depth of field quality suck.. no?
Posted by Thierry Fortier on April 6, 2005 at 2:24 pmHi everyone… dont you think After effect should add a better quality alternative for that boxed blur DoF… for people who have lot of time to render..? the quality is quite crappy and i didnt see any option for get a better blur quality…
no?
thierry
Thierry Fortier
Concepteur/Realisateur
Musiqueplus MusimaxThierry Fortier replied 21 years, 5 months ago 4 Members · 6 Replies -
Chris Smith
April 6, 2005 at 2:39 pmdid you set the composition settings to advanced 3D renderer instead of the normal one? The norml one looks like a terrible box blur. The advanced one looks like a very acceptible gaussian type.
Chris Smith
https://www.sugarfilmproduction.com -
Thierry Fortier
April 6, 2005 at 2:44 pmYes, advanced is on… and its still boxed… but there’s a lot of DoF…
for tiny amount its respectable but for a lot its not so good… its not gaussian at all… maybe i should do some test between advanced and standard… ill give you news soon…Thierry Fortier
Musiqueplus Musimax -
Thierry Fortier
April 6, 2005 at 3:50 pmno… there an obvious difference in the calculation from standard to advanced but it still quite basic blur made for speed… put a camera with blur boosted to 600 and play with the apertaure and focus distance on a solid square, you will see what im talking about… not a nice bokeh in any case!
Thierry Fortier
Angus Mackay
April 6, 2005 at 4:03 pmHi Thierry
you could always (with a relevant gradient map) use this
https://www.pluginz.com/product/11116
Peter Litwinowicz
April 6, 2005 at 5:03 pmYou can always try the compound blur available in our gaussian filter inside SmoothKit. https://www.revisionfx.com/smok.htm
It’s a true compound gaussian blur and not a box-filter approximate.
However, to use it as a DoF filter you’ll need to get your Z-component into a greyscale image and use that as the per-pixel kernel size “modulator” inside the SmoothKit Gaussian filter. You may also need to play some tricks with the greyscale image (like multiplying it by itself to get a “squared” value at each pixel) so that it performs nicely as a DoF filter. Remember to precomp any operations on the image used as the per-pixel filter kernel scale before using it with our plugin.
Plus you get 5 other very interesting smoothing filters that allow you to blur and preserve various kinds of image properties (like edges).
We have a free demo on the website, in the “Downloads” subsection for SmoothKit.
Cheers,
Pete Litwinowicz
https://www.revisionfx.com -
Thierry Fortier
April 6, 2005 at 6:59 pmlot of solutions… that’s good…
thanks a lot guys!
thierry
Thierry Fortier
Musiqueplus Musimax
