Activity Forums Apple Final Cut Pro Legacy AE D1 Widescreen QTs not importing w/correct aspect ratio in FCP CCIR 601 NTSC 40:27 sequence
  • AE D1 Widescreen QTs not importing w/correct aspect ratio in FCP CCIR 601 NTSC 40:27 sequence
    Posted by Billy Spence jr on March 28, 2012 at 10:02 pm
    Tried multiple times to render out an After Effects NTSC Quicktime in Animation codec that will import into FCP with the correct 16:9 aspect ratio. AE comp settings are NTSC D1 Widescreen with a pixel aspect ratio set at D1/DV NTSC Widescreen(1.21). Final Cut Pro sequence setting is CCIR 601 NTSC 40:27. Unsure how to correct this. Please advise. Thanks!
    Andy Murphy replied 13 years, 8 months ago 2 Members · 1 Reply
  • Andy Murphy
    December 12, 2012 at 2:20 pm
    I am having this same issue. Did this ever get resolved? Thanks.
