Activity Forums Adobe After Effects AE CS6 Ray-trace
  • AE CS6 Ray-trace
    Posted by Chandra on July 8, 2012 at 6:11 pm
    Hi there, I have searched the forums for this subject and can’t seem to find an answer, I apologize in advance if I missed it somewhere.
    I have read up on the new Ray-trace feature in AE and watched John Dickinson’s tutorials on the new feature:
    https://www.motionworks.com.au/after-effects-cs6-3d-material-template/
    I want to take an .ai file created and give it some depth in AE using the new ray-trace features. After exploring I realize it does not accept masks. So does this new feature only work with text and basic shape layers?
    I tried copying my .ai outlines as a shape layer, but it does this by creating a mask therefore not giving me the extrude options.
    Does anyone know if there is a work around to get my eps or ,ai file in as a 3D object in AE so I can use the new ray-trace features?? I am hoping it is something super silly I am not seeing 🙂 I will keep playing and searching for answers, I will post back anything I find 🙂
    Thanks in advance!
    ~Chandra
    Stuart Smith replied 14 years, 2 months ago 5 Members · 9 Replies
  • 9 Replies
  • Roland R. kahlenberg
    July 8, 2012 at 6:50 pm
    CS6 can only extrude text and shape layers. You should import the AI file into AE, drop it into a comp and convert it into a shape layer – Layer>Create Shapes from Vector Layer.
    An alternative is to select the mask’s path property and paste it a Shape Layer’s Path property.
    HTH
    RoRK
    Intensive AE & Mocha Training in Singapore and Malaysia
    Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
  • Erik Waluska
    July 8, 2012 at 6:59 pm
    Be sure that text is converted to outlines and that each shape is on its own layer and import into AE as a composition (retain layer sizes option is usually best). Then open the composition, select the layers and go to layer>create shapes from vector layer. Then of course make them 3D, set up your lights, camera, etc.
  • Erik Waluska
    July 8, 2012 at 7:10 pm
  • Carlos Dee
    July 9, 2012 at 6:13 am
    import your .ai into after effects, then right click on it on the timeline and choose create shapes from vector as shown below
    then after that make sure the layer is in 3d then on comp settings change the camera from classic to ray traced then go to your object/shape layer and extrude it like this pic
    extrusion depth and thats it put the camera on custom setting 1 so you can see it better
  • Chandra
    July 9, 2012 at 4:16 pm
    wow, thanks everyone! I was about to give up and use the zaxwerks plugin! I’ve been using AE for a long time, but have never used that convert to shape layers option! I am sooo happy to have learned a new thing. I had attemoted to copy the paths and that didn’t work, but the converting to shape layers worked perfectly! Now to get a new graphics card to handle the render haha… 8 hours for 10 seconds! yikes 🙂
    Thanks for all your time! Much appreciated!
    ~Chandra
  • Chandra
    July 9, 2012 at 9:57 pm
    Im considering the Quadro 4000 for my 2008 Mac Pro, Ive searched and that seems to be the best for using with the CS6 suite. The higher end nvidia cards seem to only work on PC :(, anyone think the 4000 is a bad choice? I am basically fixing up my computer best I can until Apple releases new ones.
    Thanks again!
    https://www.nvidia.com/object/premiere-pro-cs6.html
  • Carlos Dee
    July 13, 2012 at 3:00 am
    i just got my quadro 4000 today im running a macpro 12core 12gb ram i also have the 5770 and the quadro 4000 im experiencing more lag when i use cs6, i dont know why maybe my settings arent right but im already pissed off!!! >(
  • Stuart Smith
    July 13, 2012 at 1:55 pm
    When the 4000 is installed correctly with the correct drivers it’s well worth the money, at least we think it is. The decrease in render times is absolutely amazing
    Carlos, I’m not sure why yours isn’t working, do you have the correct drivers? is your system compatible? Is AE configured correctly? You can download this free app that lets you know the status of your cuda card.
    This is a download
    https://sourceforge.net/projects/cuda-z/files/cuda-z/Beta/CUDA-Z-0.6.133-SVN.dmg/download
    Let me know if you need any more specific info
    Stuart
  • Stuart Smith
    July 13, 2012 at 2:02 pm
    Don’t forget to clear your cache. CS6 and Cuda uses your cache a great deal
