Activity Forums Adobe After Effects AE CS6 Crash On Startup
  • AE CS6 Crash On Startup
    Posted by James Archibald on November 11, 2013 at 1:21 am
    Hi there,
    I just upgraded my Graphics card from a GTX480 to the brand new GTX 780 Ti and was looking forward to the increased performance in After Effects. Unfortunately it crashes on startup now.
    After Effects error: Crash in progress. Last logged message was: (9384) (GPUManager) (2) Sniffer Result Code: 3
    I found a couple of other threads with the same issue, but the responses identified it as an AMD Radeon issue and this is definitely an Nvidia card!
    Running the latest drivers on Windows 7.
    The graphics card is the only change on the system between AE working and not working, so it’s definitely the issue. Any help would be marvellous.
    Card info:
    Manufacturer: NVIDIA
    Model: GeForce GTX 780 Ti
    Device ID: 10DE-100A
    Revision: A2
    Subvendor: NVIDIA (10DE)
    Current Performance Level: Level 1
    Current GPU Clock: 324 MHz
    Current Memory Clock: 324 MHz
    Voltage: 0.887 V
    Bus Interface: PCI Express x8
    Temperature: 29 °C
    Driver version: 9.18.13.3165
    BIOS Version: 80.80.30.00.01
    Physical Memory: 3071 MB
    Virtual Memory: 3072 MB
    James Archibald replied 12 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
