Activity Forums Adobe After Effects AE CS6 and Mocha
  • AE CS6 and Mocha
    Posted by Eric Kirk on May 18, 2012 at 12:43 pm
    Hello,
    Does anyone know how to changed the default path for Mocha in AE CS6?
    My problem is if I hit “track in mocha” (under Animation tab), it opens up the Mocha for AE version that came with CS6 and not the Mocha for AE V3.0 that I just purchased.
    I really don’t normally use that feature via animation but I suppose I’d like it to work if I do. 🙂
    Eric
    Eric D. Kirk
    http://www.kirkproductions.com
    Eric Kirk replied 14 years, 4 months ago 2 Members · 4 Replies
  • Roland R. kahlenberg
    May 18, 2012 at 3:06 pm
    Good question Erik. I think mochaImport+ helps with this. Unfortunately, I haven’t tested mocha V3.0 via the menu item or with mochaImport+. You should visit the Imagineer Systems site forum with your Q if you need a quick answer.
    Cheers
    RoRK
    Intensive AE & Mocha Training in Singapore and Malaysia
    Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
  • Eric Kirk
    May 18, 2012 at 7:26 pm
    Thanks.
    I do use Mocha Import+ so I suppose I don’t really need it then.
    Eric
    Eric D. Kirk
    May 18, 2012 at 7:34 pm
    Hi Erik, just to be clear, I’ve not tested mochaImport+ nor CS6’s menu item that activates mochaAE. I do however have mochaPro V3 and mochaImport+. Do let us know should you find a solution to activate mocha V3 using AE’s menu item/command.
    TIA
    RoRK
  • Eric Kirk
    May 18, 2012 at 7:42 pm
    Oh, it’s no problem. I’ve tested Mathias’s MochaImport+ and I know he already prepped it for CS6.
    THanks,
    Eric
    Eric D. Kirk
